I am having difficulty removing my Driver's Side 1/2 Axle. When I use the 2 Jaw Puller to push the Axle through the Front Hub I can only get the Axle part of the way through the Hub before the Bollt of the 2 Jaw Puller starts to rub against one side of the Hubs Hole. I am afraid to go any further as the HUb Hole may get damaged. While attempting this I have the Steering Arm ball joint disassembled and the Front Wheels turned to the far left. Do you have any suggestions ?
Thank You
CHF
Thank You
CHF
Dec 16, 2007 at 9:51 PM
