[quote:200a46cfb9="joseph ruiz"]Mr. Razmataz,did the computer relearn procedure with no luck,but check this out..my old computer did'nt recognize any problems,and no check engine light never came on..put the new one in and light came on and it recognizes the map to be bad,but it checks out o.k plus its also new!SO....we sent the new computer back to switch with another new one,it shoulld be here today.if light comes on again & everything checks out to be o.k could there be somthing wrong with my distriburator????what would be my next move????[/quote:200a46cfb9]
if you have no codes then there is nothing wrong with the car, the MAP sensor changes the air fuel ratio for different elevations, if your getting a code for it something is wrong with it, the code means the MAP sensor circuit, not just the map sensor
Apr 11, 2008 at 5:12 AM
