I have a 1990 Caddilac sedan deville I have 3 open ckts...... no fuses are blown so we aren't shorted to ground anywhere. Every other device and light on the car work as they are supposed to, just all lights to the rear are out. I have power to the antenna , it works fine. I also have power to the trunk closure, it works fine. What I am missing is the voltage on the BROWN wire to the tail, license plate and marker lamps, I'm missing the voltage to the YELLOW left and right blinkers and I'm missing the the back up lights which are the light green. These are from multiple sources....... light switch for the tail and marker lamps. The gear selector for the back up lamps and the blinkers that end up at the flasher thru the turnsignal switch. With opens from 3 directions, seems that a mid way connector hiding somewhere is my villian. I initially thought I had a bad body ground which would explain 3 different things going bonkers at once, but NO, I have ground everywhere. I have checked the connector under the rear bumper and the wiring harness that feed all the lights in the rear, all good, is there another connector b4 it gets to the front?? arrrrgh
Mar 17, 2010 at 9:15 AM
