1988 Cadillac Deville
1988 CADILLAC DEVILLE
GRANYGREAT2
Air Conditioning problem
1988 Cadillac Deville V8 Front Wheel Drive 93000 miles
ac will not blow through the dash vents only below dash on your feet. we had it checked and the guy said it wasn't suppose to but it should I think
May 20, 2010 at 10:23 PM
FACTORYJACK
  • 4,159 POSTS
Unless you are selecting full heat, it should blow through other than the floor vents. In max cold setting, it should most definately blow out dash vents. You could possibly have a vacuum leak in the engine compartment, or under the dash. You could also have a faulty A/C programmer.
May 20, 2010 at 11:01 PM
