this is the 3rd alter. in 1 1/2 weeks...the battery is new. the voltage was 14.5 before, then i noticed that the engine compartment light wasnt as bright. rechecked the alter. and it showed 12 volts. after i turned the heat and the headlights on. the onboard diagnostic shows code 16. noone seems to know what the problem is...there are no fusible links from the alternator, no fuses blown and an ammeter test was done and showed nothing. neg. ground wires were cleaned and checked.
Dec 19, 2007 at 6:23 PM
