2005 Cadillac CTS Transmission drops to 1st before stopping
2005 CADILLAC CTS
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
BURN77
05' CTS, at times, will feel like it is dropping down to a lower gear too quickly prior to coming to a stop. It almost feels like the brakes are locking shut or we are being rear ended. If you put the car in neutral when coming to a stop, the jolt does not occur. We had the transmission fluid and filter changed, and it was fine for 100 miles then the problem began again. The car sat for a week and the battery ended up running low and we had to boost it. After that, we have gone another 100 miles and the problem has not re appeared. Could this be a computer issue?
Aug 4, 2010 at 11:07 AM
FACTORYJACK
  • 4,159 POSTS
I would'nt think computer issue at this time. It could be fluid related, sticking valves or something. The question is, will it continue to happen. I would drive it as normal and see if it becomes repetitive. Was the engine or transmission control module reprogrammed rcently? It may have an adapted issue that may correct itself.
Aug 4, 2010 at 11:25 PM
BURN77
Thank you.
Aug 12, 2010 at 7:25 PM
