Can I change the oil and filter my self I can not get the filter to come off
Sep 29, 2008 at 7:47 PM
BMRFIXIT
CERTIFIED EXPERT
PCM will store the codes and or it should
and dealer shop should be able to retrieve them codes
get another opinion try a different shop
suspect fuel peddle sensor
good luck
[quote:e0bb6ce03c="davplmbr386"]Engine Mechanical problem
2005 Cadillac CTS 6 cyl Front Wheel Drive Automatic 50,000 miles
Can I change the oil and filter my self I can not get the filter to come off[/quote:e0bb6ce03c]
Apr 20, 2009 at 5:15 PM
FACTORYJACK
CERTIFIED EXPERT
I have seen some of the oil filter housing caps tight, to the point it needs 1/2" drive long ratchet to break it loose. There is no reason you couldn't change the oil yourself, it takes 6 quarts 5w-30 synthetic, and a 24mm socket for the filter access. You may have to have someone break it loose for you, if you don't have the provision.
