2004 Cadillac CTS WATER leaking through dashboard to passen
2004 CADILLAC CTS
69,540 MILES • 6 CYL • AWD • AUTOMATIC
LISACTS10
there is a sound of a mini waterfall/ water faucet while driving and water seems to be dripping through under dashboard into passenger side rug.
what is this and is it serious??? have long drive ahead.
Feb 3, 2010 at 3:47 PM
FACTORYJACK
  • 4,159 POSTS
It all depends on how serious you want a water leak to be, obviously it is not right. As far as what is causing it, it could be one of many things. The windshield, cowl area body seams, clogged evaporator drain. A fella I work with currently has the dash out of a CTS to seal where the hvac case splits, about a 10 hour(flat rate) job. Not to mention the carpet getting wet, possibility of mold/mildew. First step is to stop the carpet from getting wetter, and then getting access to see the point of entry. We use a shower head, or hose, and do alot of visual inspection and teardown for visual access.
Feb 3, 2010 at 11:08 PM
FUNKYROB
  • 4 POSTS
[quote:c1ee7ef480="lisacts10"]2004 Cadillac CTS 6 cyl All Wheel Drive Automatic 69540 miles
what is this and is it serious??? have long drive ahead.[/quote:c1ee7ef480]
If the 04 is the same as my '03, it's likely just a clogged drain for the air conditioning.
I found the drain tube behind the carpet to the right of the gas pedal. (not sure if it's the same place as '04). I disconnected the tube and shoved a stiff wire to block any clog and put the tube back. If you're too scared to try, you could always turn off the a/c.
Mar 2, 2010 at 2:37 PM
