what is the torque for the heads
2003 CADILLAC CTS
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
ESPINO
i am repairing the heads of this car.
whats the torque i need to apply?
thanks a lot.
Jun 29, 2010 at 3:28 PM
FACTORYJACK
  • 4,159 POSTS
Fastener Tightening Specifications
Application
Specification
Metric
English
Accessory Mounting Bracket Bolt
35 N·m
26 lb ft
A/C Compressor Mounting Bolt
20 N·m
15 lb ft
Battery Cable to Battery Bolt
17 N·m
13 lb ft
Battery Negative Cable to Side Rail Bolt
36 N·m
27 lb ft
Battery Positive Cable to Underhood Fuse Block Nut
15 N·m
11 lb ft
Blow by Plate to Cylinder Block Bolt
8 N·m
71 lb in
Camshaft Bearing Cap Bolt
8 N·m
71 lb in
Camshaft Cover Bolt
8 N·m
71 lb in
Camshaft Position (CMP) Sensor Bolt
8 N·m
71 lb in
Camshaft Sprocket Bolt - First Pass
50 N·m
37 lb ft
Camshaft Sprocket Bolt - Second Pass
60 degrees
Camshaft Sprocket Bolt - Third Pass
15 degrees
Coil Ground to Left Cylinder Head Bolt
50 N·m
37 lb ft
Connecting Rod Cap Bolt - First Pass
35 N·m
26 lb ft
Connecting Rod Cap Bolt - Second Pass
45 degrees
Connecting Rod Cap Bolt - Third Pass
15 degrees
Coolant Heater Ground Lead Bolt
8 N·m
80 lb in
Coolant Jacket Plug
65 N·m
48 lb ft
Coolant Jacket Support Plug
65 N·m
48 lb ft
Crankcase Vent Housing Bolt
8 N·m
71 lb in
Crankcase Ventilation Tube Adapter Bolt
8 N·m
71 lb in
Crankshaft Balancer Bolt
20 N·m
15 lb ft
Crankshaft Bearing Bridge Adjusting Sleeve
20 N·m
15 lb ft
Crankshaft Bearing Bridge Bolt
20 N·m
15 lb ft
Crankshaft Bearing Cap - First Pass
50 N·m
37 lb ft
Crankshaft Bearing Cap - Second Pass
60 degrees
Crankshaft Bearing Cap - Third Pass
15 degrees
Crankshaft Drive Gear Bolt - First Pass
250 N·m
184 lb ft
Crankshaft Drive Gear Bolt - Second Pass
45 degrees
Crankshaft Drive Gear Bolt - Third Pass
15 degrees
Crankshaft Position (CKP) Sensor Bolt
8 N·m
71 lb in
Crankshaft Reluctor Ring Screw
15 N·m
11 lb ft
Cylinder Head Bolt - First Pass
25 N·m
18 lb ft
Cylinder Head Bolt - Second Pass
90 degrees
Cylinder Head Bolt - Third Pass
90 degrees
Cylinder Head Bolt - Fourth Pass
90 degrees
Cylinder Head Bolt - Fifth Pass
15 degrees
Drive Belt Tensioner Bolt
35 N·m
26 lb ft
ECM Bracket to Cylinder Head Bolt
20 N·m
15 lb ft
ECM Bracket to Intake Plenum Bolt
8 N·m
71 lb in
ECM to Bracket Nut
8 N·m
71 lb in
Engine Coolant Temperature (ECT) Sensor
18 N·m
13 lb ft
Engine Ground Lead to Left Cylinder Head Bolt
30 N·m
22 lb ft
Engine Mount Bracket Bolt
60 N·m
44 lb ft
Engine Mount Nut
80 N·m
59 lb ft
Engine Wiring Harness Ground Lead Bolt
9 N·m
80 lb in
Engine Wiring Harness Retainer to Oil Pan Bolt
50 N·m
37 lb ft
EVAP Canister Purge Valve Bracket Bolt
8 N·m
71 lb in
Exhaust Manifold Nut
20 N·m
15 lb ft
Exhaust Manifold Stud
30 N·m
22 lb ft
Flywheel Bolt - First Pass
65 N·m
48 lb ft
Flywheel Bolt - Second Pass
30 degrees
Flywheel Bolt - Third Pass
15 degrees
Front Air Inlet Panel Assembly Fastener
6 N·m
53 lb in
Fuel Rail Bolt
8 N·m
71 lb in
Generator Mounting Bolt
35 N·m
26 lb ft
Ignition Coil Cassette Bolt
8 N·m
71 lb in
Intake Manifold Bolt
20 N·m
15 lb ft
Intake Manifold Flange Bolt
20 N·m
15 lb ft
Intake Plenum Bolt
20 N·m
15 lb ft
Intake Plenum Tuning Solenoid Bolt
8 N·m
71 lb in
Intake Plenum Tuning Valve Bolt
8 N·m
71 lb in
Knock Sensor Bolt
20 N·m
15 lb ft
Knock Sensor Wire Harness Bracket Bolt
8 N·m
71 lb in
Oil Baffle Bolt
8 N·m
71 lb in
Oil Cooler Cover Bolt
20 N·m
15 lb ft
Oil Cooler Feed and Return Lines to Engine Block
30 N·m
22 lb ft
Oil Cooler Inlet and Outlet Nut
30 N·m
22 lb ft
Oil Cooler Pipe Fitting to Oil Cooler
30 N·m
22 lb ft
Oil Filter Adapter Bolt
20 N·m
15 lb ft
Oil Filter Adapter Female Screw
25 N·m
18 lb ft
Oil Filter Adapter Plug
25 N·m
18 lb ft
Oil Filter Cartridge Housing Drain Plug
10 N·m
89 lb in
Oil Filter Cartridge Plastic Cap to Adapter
25 N·m
18 lb ft
Oil Intake Pipe Bolt
8 N·m
71 lb in
Oil Intake Pipe Brace Bolt
8 N·m
71 lb in
Oil Level Indicator Tube Bolt
20 N·m
15 lb ft
Oil Pan Bolt
15 N·m
11 lb ft
Oil Pan Drain Plug
10 N·m
89 lb in
Oil Pressure Sender
35 N·m
26 lb ft
Oil Pump Bolt
20 N·m
15 lb ft
Oil Pump Cover Bolt
8 N·m
71 lb in
Power Steering Hose Retaining Nut
8 N·m
71 lb in
Power Steering Pump Mounting Bolt
35 N·m
26 lb ft
Remote Power Steering Fluid Reservoir to Cylinder Head Mounting Bolt
25 N·m
18 lb ft
Remote Power Steering Fluid Reservoir to Intake Plenum Mounting Bolt
9 N·m
80 lb in
Spark Plug
25 N·m
18 lb ft
Surge Tank Outlet Pipe to Vent Housing Bolt
9 N·m
80 lb in
Thermostat Housing Bolt
20 N·m
15 lb ft
Threaded Block Heater
60 N·m
44 lb ft
Throttle Body Bolt
8 N·m
71 lb in
Throttle Body Heater Inlet Hose/Pipe Bolt
9 N·m
80 lb in
Timing Belt Front Cover Bolt
8 N·m
71 lb in
Timing Belt Idler Pulley Bolt
40 N·m
30 lb ft
Timing Belt Rear Cover Bolt
8 N·m
71 lb in
Timing Belt Rear Cover Threaded Pin
10 N·m
89 lb in
Timing Belt Tensioner Bracket Bolt
40 N·m
30 lb ft
Timing Belt Tensioner Pulley Nut
20 N·m
15 lb ft
Torque Converter Bolt
63 N·m
46 lb ft
Transmission Fluid Cooler Pipes Retaining Bolt
25 N·m
18 lb ft
Transmission Manual Shift Shaft Nut
9 N·m
80 lb in
Transmission Mounting Bolt M10
50 N·m
37 lb ft
Transmission Mounting Bolt M12
75 N·m
55 lb ft
Transmission Mount Nut
60 N·m
44 lb ft
Transmission Support Mounting Bolt
60 N·m
44 lb ft
Vacuum Brake Booster Fitting
25 N·m
18 lb ft
Water Crossover Bolt
30 N·m
22 lb ft
Water Pump Bolt
25 N·m
18 lb ft
Water Pump Pulley Bolt
8 N·m
71 lb in
Jun 29, 2010 at 11:47 PM
ANDREK1876
  • 8 POSTS
is this the same specs for the 08 cts v7 rwd engine?
Jul 8, 2015 at 6:58 PM
Are you referring to the 3.6L V6? When you say V7, those are two different designs. I need to know the engine code from the VIN (8th digit from left). One is a V and the other is a 7. I need to know which one to provide specs.
See picture 1.
Let me know which one you have. Also, let me know if you need torque sequence or any other information.
Mar 17, 2020 at 6:30 PM
