2003 Cadillac CTS THERMOSTAT LIGHT , KEYLESS ENTRY
2003 CADILLAC CTS
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOM Y
THE ENGINE LIGHT HAS BEEN ON DUE TO A THERMOSTAT PROBLEM. I HAVE BEEN DRIVING IT FOR SOME TIME. I WOULD LIKE TO KNOW IF THERE WAS A RECALL ON FAULTLY THERMOSTAT. I HAVE HAD NO PROBLEM WITH OVERHEATING. ANOTHER PROBLEM THAT STARTED LAST WEEK IS THE KEYLESS ENTRY REMOTE IS NOT WORKING. I HAVE PUT NEW BATTERY IN BOTH REMOTES. WHAT COULD THE PROBLEM BE
. i ALSO CHECK ALL FUSES UNDER THE HOOD.
Jun 15, 2010 at 7:53 PM
FACTORYJACK
  • 4,159 POSTS
No recall on thermostat. I am assuming that you have a P0128 for failing to reach operating temperature. The thermostat is stuck open, or opening prematurely. First thing on the keyless entry would be to test the fobs, this requires a special tool. Next would be to attempt programming, if it won't program, you could have a fault with the remote control door lock receiver/antenna module.
Jun 23, 2010 at 10:56 PM
