hello i have a 2003 cadillac cts with a 3.2 L v6 and recently had the serpentine belt shred up and after replacing it drove 5 minutes and the car died and after further diagnosing and scanning for codes i had a camshaft position sensor code that said out of range so i replaced it and nothing ..i come to realize some strands of the serpentine belt walked in the timing belt cover and wrapped around the crankshaft sprocket and looks to have caused the timing belt to jump some teeth on the crankshaft sprocket . i reset the timing marks on the cover for the four cams and the crankshaft and the timing was way off so i replaced the timing belt and reset the marks and all looks well and there are no more codes at all ..now my question is could there be any internal damage to the valves or anything else that could cause it not to start at all because when i turn the car over it makes a strange whistle noise that sounds like a valve stuck open or something not normal
Dec 29, 2008 at 1:32 PM
