2003 Cadillac CTS car cutting off
2003 CADILLAC CTS
113,000 MILES • 6 CYL • 2WD • AUTOMATIC
CADDILUVER
I was at a stop light and the car cut off, but it started up again. than i was at the store and i left the car running and when i returned the car had cut off. after several attempts it started up again it seemed to be the fuel pump than i noticed that my battery volts were at about 12 volts. i dont know exactly the promblem but i am going to get a battery tommorow. please help if you have any suggestions. thanks
Jun 10, 2009 at 9:03 PM
FACTORYJACK
  • 4,159 POSTS
Battery should not be causing it to stall. Do you have to wait a bit for it to restart? My guess is you have a crank sensor failing hot. If you can find the connector at rear of left head, check the hot resistance. It should read around 950 ohms.
Jun 10, 2009 at 10:21 PM
