1994 Cadillac CTS shifting
1994 CADILLAC CTS
100,000 MILES • V8 • FWD • AUTOMATIC
BRYAN LANHAM
only have reverse and lower gears is it the shift solenoid if so where is it
Mar 12, 2010 at 7:20 AM
FACTORYJACK
  • 4,159 POSTS
Is the check engine light on. Inspect the shift solenoids by removing the pan and 'dogleg' shaped screen. There is a filter in between the solenoids, on the early style it wasn't retained and eventually would push out and break the solenoid. A new solenoid kit will include a bracket and longer valve body bolt. The lower valve body will need removed if you need to service solenoids.
Mar 12, 2010 at 11:34 PM
