1998 Cadillac Concours engine stops at turns
1998 CADILLAC DEVILLE CONCOURS
68,000 MILES • V8 • FWD • AUTOMATIC
BOORMAND
We have a 1998 Cadillac deVille Concours that has been meticulously maintained. Recently, the car has begun to stall when making a turn at very low speed rates. The stalling, so far, has only occured at those moments and can be avoided if it is put in neutral and the engine revved while waiting. Our mechanic has no idea of what is going on and cannot seem to find the answer nor fix the problem. Any ideas as to what is going on?
Jan 4, 2009 at 2:55 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds liek it may be aproblem with the Idle Speed Control Motor.First try cleaning out the throttle bore with carb cleaner and a rag, then remove the ISC motor and clean it as well. This may work, but sometimes the ISC motors get slow to react and wont set failure codes due to the fact they still work
Jan 4, 2009 at 8:03 PM
