1997 Cadillac Concours
1997 CADILLAC DEVILLE CONCOURS
COMPETITIVE CUSTOMS
Engine Mechanical problem
1997 Cadillac Concours V8
CHANGED FUEL PUMP AND STILL CANT HEAR PUMP COME ON WILL START WITH STARTER FLUID SPRAYED ALSO CHANGED PUMP RELAY AND FUSES TO NO AVAIL CAN YOU HELP.
Apr 11, 2008 at 10:35 PM
BUZZSAW
  • 1,198 POSTS
[quote:04d82d015a="competitive customs"]Engine Mechanical problem
CHANGED FUEL PUMP AND STILL CANT HEAR PUMP COME ON WILL START WITH STARTER FLUID SPRAYED ALSO CHANGED PUMP RELAY AND FUSES TO NO AVAIL CAN YOU HELP.[/quote:04d82d015a]
ck the fuses, there is also a fuse box behind the rear seat in the trunk, remove the carpeted peice its only velcroed on. The fuse also blows depending on if the old pump draws to many amps
Apr 12, 2008 at 11:34 AM
