1994 Cadillac Concours SERVICE RIDE CONTROL
1994 CADILLAC DEVILLE CONCOURS
160,000 MILES • V8 • FWD • AUTOMATIC
JAMES TIMMONS
THE MECHANIC TOLD ME I NEED A POWER CONTROL MODULE FOR MY MOTOR AND TRANSMISSION BUT WHAT DOES THAT HAVE TO DO THE RIDE CONTROL
Feb 29, 2008 at 6:41 PM
BUZZSAW
  • 1,198 POSTS
[quote:2cdb356685="james timmons"]Suspension problem
1994 Cadillac Concours V8 Front Wheel Drive Automatic 160000 miles
THE MECHANIC TOLD ME I NEED A POWER CONTROL MODULE FOR MY MOTOR AND TRANSMISSION BUT WHAT DOES THAT HAVE TO DO THE RIDE CONTROL[/quote:2cdb356685]
thats not what you need at all, you either need a relay put on the rss module to bypass it or a wire needs to be cut, the thing is the electrical part of one of you shocks is bad shocks are fine, replacement parts are without the electrical part of the shocks, the fix is the relay or to cut a wire on the module, which is either under your driver seat(cut a wire) or in the trunk on the rear seat back behind the panel (which is a relay addition)
Mar 5, 2008 at 8:23 AM
