1994 Cadillac Concours Gas Tank filler
1994 CADILLAC DEVILLE CONCOURS
180,000 MILES • V8 • FWD • AUTOMATIC
JWARRIOR
How do you take the filler out and replace it.
Oct 7, 2010 at 1:20 PM
FACTORYJACK
  • 4,159 POSTS
I would assume you are talking about the fill pipe? I will research and get back to you. It will probably be tomorrow, I have no service info for 1994 in front of me.
Oct 7, 2010 at 11:21 PM
FACTORYJACK
  • 4,159 POSTS
Alldata and Mitchell have nothing, and the factory 95 setrvice manual does not list procedure for filler neck specifically. It has three screws that secure it to the upper pocket. It then looks like it is secured to the rear body by a clip. You will need to disconnect the hoses either from the filler or the tank. There also may be a ground strap on the upper reaches of the fill pipe. It may benefit to remove the rear tire and wheelhouse liner for more access.
Oct 8, 2010 at 1:03 PM
