When you set the timing for the cams do you use the the marks 1,2,3,4 on the gears? On the crankshaft when the mark is at 6:00 that is TDC correct? But it is supposed to be at 60 degress BTDC when the cams are timed, is this correct?
Thanks
Thanks
Aug 31, 2009 at 1:21 PM
