2000 Catera w/ ABS/ TC/ Speedometer Problem. HELP
2000 CADILLAC CATERA
FMOKHTAR
I just bought a 2000 Cadillac Catera with 76,000 miles and is a V6. The problem I'm facing is that the "Check Engine","TC", and "ABS" light is on. The Speedometer is working only intermittently, but most of the time the needle is dead and the steering wheel becomes very hard, as if the power steering is affected by these problems.
I've checked the internet for answers and many Catera owners report the same EXACT!! problem but there is no answer to resolve the problem. Please someone help me. Email [email protected].
Feb 14, 2007 at 5:20 PM
2CARPRO JACK
  • 11,533 POSTS
Scan it for the codes first. Sounds like the VSS (Vehicle Speed Sensor) might be going out. Get the codes and lets go from there
Feb 14, 2007 at 6:59 PM
BUZZSAW
  • 1,198 POSTS
[quote:86db09c2a7="fmokhtar"]I just bought a 2000 Cadillac Catera with 76,000 miles and is a V6. The problem I'm facing is that the "Check Engine","TC", and "ABS" light is on. The Speedometer is working only intermittently, but most of the time the needle is dead and the steering wheel becomes very hard, as if the power steering is affected by these problems.
I've checked the internet for answers and many Catera owners report the same EXACT!! problem but there is no answer to resolve the problem. Please someone help me. Email [email protected].[/quote:86db09c2a7]
or a abs sensor is bad in the right front wheel
Sep 17, 2007 at 1:34 PM
TORUS
[quote:e66971f293="2CarPro Jack"]Scan it for the codes first. Sounds like the might be going out. Get the codes and lets go from there[/quote:e66971f293]
I have the same problem, I replaced the VSS (Vehicle Speed Sensor) (attached to transm.) Still ABS, TC, Check Engine light On.
Any help would be greatly appriciated.
98 catera.
Feb 29, 2008 at 8:11 PM
SWANTZILLA
Same problem here. I get codes u2108 and p1700. It is very intermittent. The lights will go on, speedo stops working then 10 minutes later all is well.
Mar 27, 2008 at 2:20 PM
MOHEGAN42
I believe I responded to this question once already, but it's not listed here so I'll re-respond. The problem IS the ETCBM. I guarantee it. I bought a 2000 Catera with the same problem, same codes, spend all day troubleshooting it, and it wasn't until I got home and did an internet search until I found my problem. I also did a search for part availability (which was like $700.00 approx) and stumbled across an eBay posting from the manufacture (Bosch), who rebuilds your ETCBM for 159.00 which includes shipping. Problem was removing it. It’s not really that hard, but it is definitely challenging. I could do one fairly easily now (after having done one, but honestly, it sucked) It also took almost 14 days to get my car running again because like I said, it’s a rebuild of your part. You have to send yours in, and wait for the return. But if you have the time, it’s worth the pain. If you have any questions, feel free to email me. [email protected]
Dean
Apr 16, 2008 at 6:00 PM
ALVIN CARMON
  • 8 POSTS
[quote:7acddad5a0="2CarPro Jack"]Scan it for the codes first. Sounds like the VSS (Vehicle Speed Sensor) might be going out. Get the codes and lets go from there[/quote:7acddad5a0] Code 2108 and 1700
May 21, 2008 at 3:28 PM
ALVIN CARMON
  • 8 POSTS
[quote:abe19435de="2CarPro Jack"]Scan it for the codes first. Sounds like the VSS (Vehicle Speed Sensor) might be going out. Get the codes and lets go from there[/quote:abe19435de] 2108 and 1700 is the A senor on the right side or the left . front
May 21, 2008 at 3:33 PM
MASTERTECHTIM
  • 4,750 POSTS
awesome info on the ebtcm. i have a cust with same problem that i havent been able to nail down
May 21, 2008 at 3:42 PM
ALVIN CARMON
  • 8 POSTS
[quote:282cdfcb6e="Buzzsaw"][quote:282cdfcb6e="fmokhtar"]I just bought a 2000 Cadillac Catera with 76,000 miles and is a V6. The problem I'm facing is that the "Check Engine","TC", and "ABS" light is on. The Speedometer is working only intermittently, but most of the time the needle is dead and the steering wheel becomes very hard, as if the power steering is affected by these problems.
I've checked the internet for answers and many Catera owners report the same EXACT!! problem but there is no answer to resolve the problem. Please someone help me. Email [email protected].[/quote:282cdfcb6e]
or a abs sensor is bad in the right front wheel[/quote:282cdfcb6e] Did this work to fix the problem. I like to now. think you.
May 22, 2008 at 1:19 PM
ALVIN CARMON
  • 8 POSTS
[quote:59adc19029="swantzilla"]Same problem here. I get codes u2108 and p1700. It is very intermittent. The lights will go on, speedo stops working then 10 minutes later all is well.[/quote:59adc19029] What did you do to fix it.
May 22, 2008 at 3:53 PM
ALVIN CARMON
  • 8 POSTS
[quote:6e1dd2719f="mastertechtim"]awesome info on the ebtcm. i have a cust with same problem that i havent been able to nail down[/quote:6e1dd2719f] was this for the ABS and TC light .
May 23, 2008 at 1:18 PM
MOHEGAN42
Sorry, its called the EBTCM (Electronic Brake and Traction Control Module) also known as the ABS Module. The Ebay repair user name is bba-remaninc ($60 now). Go to ebay and sign in, go to advanced search and click by seller, enter above user name. Good luck all.
Apr 27, 2012 at 9:38 PM
RIVERMIKERAT
  • 6,110 POSTS
Thanks for the info Mohegan42. Much appreciated.
Apr 30, 2012 at 12:47 AM
