2000 Cadillac Catera looseing water
2000 CADILLAC CATERA
95,867 MILES • 6 CYL • 2WD • AUTOMATIC
JOSHUA1971
i am loosing water nsomewhere! it never puddles anywhere i park it or can i see any viseable leaks. it has a faint smell only somtimes but not often and it is not running anywhere near hot
Oct 31, 2009 at 5:17 PM
MATHIASO
  • 1,209 POSTS
you are losing colant and it must go somewhere. check beneath , around the water pump pulley, specially in the morning befor you start the car.
https://www.2carpros.com/forum/automotive_pictures/46384_water_pump_1.jpg
leak may be coming from the gasket on the water pump. If no leak is found, you will need a colant pressure test. if no leak is found after the pressure test, check status of the spark plugs.
Oct 31, 2009 at 5:38 PM
