1999 Cadillac Catera CRANKS RUNS SHUTS DOWN
1999 CADILLAC CATERA
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
DISISJC
  • 18 POSTS
This car cranks just fine runs just fine then after about 3 to 5 mins shuts down as if you turned off the ign key. Any idea.?
Jan 22, 2008 at 3:50 PM
BUZZSAW
  • 1,198 POSTS
[quote:f50ac1ef0f="disisjc"]Engine problem
1999 Cadillac Catera 6 cyl Two Wheel Drive Automatic 100000 miles
This car cranks just fine runs just fine then after about 3 to 5 mins shuts down as if you turned off the ign key. Any idea.?[/quote:f50ac1ef0f]
possiable crank sensors
Jan 22, 2008 at 4:08 PM
DISISJC
  • 18 POSTS
[quote:fd389259ad="Buzzsaw"][quote:fd389259ad="disisjc"]Engine problem
This car cranks just fine runs just fine then after about 3 to 5 mins shuts down as if you turned off the ign key. Any idea.?[/quote:fd389259ad]
possiable crank sensors[/quote:fd389259ad]
Thanks I have order the crankshaft position sensor and as soon as it comes in and I get it installed I will let you know the outcome.
Thanks
J.C.
Jan 23, 2008 at 2:30 PM
BUZZSAW
  • 1,198 POSTS
[quote:133afdae39="disisjc"][quote:133afdae39="Buzzsaw"][quote:133afdae39="disisjc"]Engine problem
This car cranks just fine runs just fine then after about 3 to 5 mins shuts down as if you turned off the ign key. Any idea.?[/quote:133afdae39]
possiable crank sensors[/quote:133afdae39]
Thanks
J.C.[/quote:133afdae39]
after you install them you will have to take it to the dealer for a crank shaft posision sensor relearn through the computer (dealer only on this)
Jan 25, 2008 at 3:46 PM
DISISJC
  • 18 POSTS
Thats the first I've read about taking to dealer. Do you mean if the car runs after installing the sensor then take to them?
Jan 26, 2008 at 7:26 PM
BUZZSAW
  • 1,198 POSTS
[quote:fd9eae8b9a="disisjc"]Thats the first I've read about taking to dealer. Do you mean if the car runs after installing the sensor then take to them?[/quote:fd9eae8b9a]
yes you will, a cps relearn needs to be done, it should run but with a ck engine lite
Jan 28, 2008 at 11:06 AM
