[quote:7161809179="timandsarah2000"]Engine Mechanical problem
1999 Cadillac Catera 6 cyl Two Wheel Drive Automatic 120000 miles
We are replacing the head gaskets on our '99 Catera. What is the importance of replacing the serpentine and timing belt tentioners within the same process?[/quote:7161809179]
why are you replacing the head gaskets? oil in the coolant?
the timming belt on a catera is crucial. it gets done every 60k. and you need special tools to do it. if you dont set it up right the car will not run right
it also is an interference motor if it breaks the valves bend
Mar 20, 2008 at 6:33 PM
