1998 Cadillac Catera car quits afer about 15 to 20 miles
1998 CADILLAC CATERA
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLUME
after driving about 20 miles the car quits and about 15 minutes later it starts back up what could this be???
Sep 6, 2008 at 10:27 PM
When it quits do below immediately
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
Sep 7, 2008 at 4:43 AM
