1987 Cadillac Brougham A/C/ belt noise
1987 CADILLAC FLEETWOOD BROUGHAM
200,000 MILES • V8 • 2WD • AUTOMATIC
REELDEN
Friend changed the water pump on 87 Caddy Brougham Fleetwood. When all the belts were put on starting it the A/C. belt squealed very loud. Belt was tight. Is it too loose or too tight? Also worked for 8 hours first day with hood up, second day 3 hours but then would not turn over, but lights worked. Would the hood light cause the battery to drain? Thank you!
Jun 6, 2010 at 3:59 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
check that there is not to much deflection in the belt, it may be a bit loose, re charge the battery and get it load tested, if it is a bit down on condition, the bonnet light may well cause it do go flat in this time frame.
mark (mhpautos)
Jun 6, 2010 at 7:11 PM
REELDEN
Thanks Mark. He replaced all 4 belts and the belt seemed tight. the A/C compressor would not make noise like belt squealing would it? If the squealing would stop could drive around and charge the battery
Thanks again
Jun 6, 2010 at 7:23 PM
