Cabin air flow
2005 TOYOTA COROLLA
164,000 MILES • FWD • AUTOMATIC
CASSIE COLLINS
Having issues with poor cabin air flow. Has been getting progressively worse. Looked at how to change filter and discovered that there was no air filter installed (I have had the car ten years and assume it has not had one for this entire time or from initial manufacture). How do I clean out the air system, is this expensive and do I need someone specialized or can a regular mechanic do it?
Jan 15, 2017 at 3:53 AM
HMAC300
  • 48,601 POSTS
check blower for working properly, then check air door. however, our manual says you do have an air filter so that can be the problem. see pictures for removal. install is reverse of removal.
Jan 15, 2017 at 8:14 AM
CASSIE COLLINS
I will check the other things. I have already checked and there is no air filter in there, there was not one installed. I have noticed that this has been an issue with some Toyota's when new from factory that they have not been installed.
Jan 15, 2017 at 2:05 PM
HMAC300
  • 48,601 POSTS
well, check other things. also, check to see if squirrel cage is loose on blower motor as that could be it or something blocking it.
Jan 15, 2017 at 3:35 PM
