Does this truck have an cabin air filter? If so I need to replace it.
2007 CHEVROLET SILVERADO
137,200 MILES • 5.3L • V8 • 2WD
RETIRED64
I would like to know if my truck has a cabin air filter.
Jul 12, 2018 at 8:00 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It appears that your does not have a cabin air filter. If you had a 2003 or older you have one. this video and guide will show you how to change it out.
https://youtu.be/Z1IPPJU68KA
and
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
Jul 12, 2018 at 8:36 AM
RETIRED64
Thanks for answering my question .
Jul 12, 2018 at 11:40 AM
96CHEV
Where do I find the air filters for the cab air conditioner heater system? (2003 model not 2005)
Apr 30, 2021 at 3:02 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
video
SANDWICHH
I have the truck listed above and my son has a 2007. We are trying to figure out where the cabin filters are. How do you find them and replace them?
Apr 30, 2021 at 3:03 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Stop looking neither one has one.
SANDWICHH
What I was afraid of. Thanks.
DOCFIXIT
  • 18,828 POSTS
I did find this video though
It shows it being replaced
SANDWICHH
No odor is not. Son was complaining of dust coming out of his vents.
DOCFIXIT
  • 18,828 POSTS
Run in re-circulation mode.
BERJANE
Does my Silverado have a cabin air filter?
HMAC300
  • 48,601 POSTS
Here is what the factory is saying
PASSENGER COMPARTMENT AIR FILTER REPLACEMENT
This Article has been updated by bulletin #PIT3330, dated December 22, 2004.
Condition/Concern:
A customer may inquire about the availability of the passenger compartment air filter.
Recommendation/Instructions:
Starting in 2003 model year, the passenger compartment air filter is no longer available as a factory option. With the redesigned HVAC case, there is no longer a cavity for the filter. The GM parts catalog indicates there is a replacement filter available; however, there is no provision for it.
DAVID WINEMAN
I cannot locate the in cabin air filter, if there is one. Where is the in cabin filter located and how do you get to it?
MHPAUTOS
  • 31,937 POSTS
Hi there ,
GM stopped using cabin air filters in 2003 and up. I attached a warranty article from GM below.
However, here is a video to show you how to do the filters if your truck is so equipped.
Please let us know if you have other questions.
DAVID MOSS
where do I find the interior cabin air filters and how to I replace them.
This guide will help and the diagrams below https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter 2002 Chevy Truck K 1500 Truck 4WD V8-6.0L VIN U Cabin Air Filter Locations View
https://www.2carpros.com/forum/automotive_pictures/12900_caf1_1.jpg
REMOVAL PROCEDURE
https://www.2carpros.com/forum/automotive_pictures/12900_caf2_1.jpg
1.If equipped, remove the IP sound insulator. 2.Remove the filter access door screw. 3.Remove the filter access door (1) from the HVAC module. 4.Remove the passenger compartment air filter (2). INSTALLATION PROCEDURE
https://www.2carpros.com/forum/automotive_pictures/12900_caf3_1.jpg
1.Install the passenger compartment air filter (2). 2.Install the filter access door (1) to the HVAC module. NOTE: Refer to Fastener Notice in Service Precautions. 3.Install the filter access door screw. Tighten Tighten the screw to 1.6 Nm (14 lb in) . 4.If equipped, install the IP sound insulator.
2CP-ARCHIVES
  • 4,540 POSTS
where is the cabin filter
REMOVAL PROCEDURE
Remove the instrument panel hush panel.
Remove the filter access door from the HVAC module.
Remove the passenger compartment air filters.
Install the passenger compartment air filters.
Install the filter access door to the HVAC module.
Tighten
Install the instrument panel hush panel.
GARBDHIFI
I am trying to locate the cabin airfilter on my chevy silverado for replacement.
MHPAUTOS
  • 31,937 POSTS
Hi there, See pic & text for cabin filter info. Mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_1_72.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_107.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic1_4.jpg
GUILLY81
can you tell me where the cabin air filter is located
Apr 30, 2021 at 3:04 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
remove the instrument panel sound insulator from under the right side of the instrument panel. then remove teh insulator from the HVAC module and you should then see the filter access door.
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_213.jpg
