Code c1515 will not clear
2010 TOYOTA COROLLA
155,640 MILES • 1.6L • 4 CYL • 2WD • MANUAL
BERNARD TEASE
c1515 dtc code doesn't want to clear off. what could be the problem or can you please give me specs to repair this problem?
Mar 30, 2022 at 7:22 AM
BORIS K
  • 836 POSTS
Your vehicle is equipped with electrical power steering.
This DTC does not indicate a malfunction. The power steering ECU stores this DTC when it determines that the torque sensor zero-point calibration has not been performed.
With a suitable scan tool initiate and perform the torque sensor zero-point calibration.
You might have to perform this calibration up to three times before the fault can be cleared.
Cheers, Boris
Mar 30, 2022 at 9:32 AM
