Basically the org and tan in D are your motor control wires and the control motor will apply voltage to one of the wires and ground the other if it wants to change the direction of the motor.
Looks like you are on step 5 of this test based on those numbers. Unhook the connector and put your meter on ohms and measure G to F on the encoder. Let me know what that reading is.
If that is okay.
Step 6 is to check each of the wires on the connector to ground. Put the black lead on a good ground and then touch the red lead of your meter to each of these pins in this connector. There are 8 of them.
Let me know the result of this and we can go from there. Thanks
Dec 11, 2019 at 5:37 PM
