Recently, my car needed a jump start, and I found the battery voltage was low. I replaced the battery and also changed the brake pads at the same time. After that, a C0074 code appeared. I tried clearing it using a TOPDON OBD2 scanner, but it wouldn’t clear.
Does anyone know which scanner can successfully reset this code? I suspect it’s related either to the low voltage issue or the brake pad replacement. The car is old and has some rust on the brake rotors as well.
Any advice would be appreciated!
Nov 11, 2025 at 2:09 PM
