c0035 left front wheel speed sensor circuit fault
2007 GMC CANYON
180,000 MILES • 3.7L • 5 CYL • 4WD • AUTOMATIC
MARK FRIZZELL
  • 142 POSTS
I keep getting this code. I have replaced hub, speed sensor, rotor, rotor bracket. I do have continuity on wires from sensor to module. It was engaging ABS every time I would brake at a stop until I changed the rotor and bracket. I think it was rubbing but now I am still getting light and code?
Apr 7, 2017 at 11:39 AM
Hello, it sounds like you have a short in the controller. In particular the left front actuation solenoid.
Here is a guise to help you replace it.
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
Best, Ken
Apr 9, 2017 at 5:49 PM
MARK FRIZZELL
  • 142 POSTS
We replaced complete abs unit, new hubs with sensors, rotors , pads . Code is c0035
Apr 9, 2017 at 6:37 PM
Must be missing something, Here is the wiring diagram for the circuit. Double check the connector to make sure one of the terminals has not pulled out of the connector.
I assume the light was on before changing the hub with sensor?
Apr 9, 2017 at 7:19 PM
MARK FRIZZELL
  • 142 POSTS
Went back to drawing board, unplugged both front sensors, put DVM on each side checked ohm resistance first on right side I got 435 however on the right side I got no resistance
Apr 10, 2017 at 9:31 AM
MARK FRIZZELL
  • 142 POSTS
Sorry I meant the other way round , no resistance on left side which is where we seem to have issues I should have resistance correct?
Apr 10, 2017 at 9:33 AM
Yes you should. Try this test,
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
See if the sensor is working
Let me know, Ken
Apr 10, 2017 at 10:28 AM
MARK FRIZZELL
  • 142 POSTS
Hey Ken, bad new hub and sensor, thx for your help
Apr 10, 2017 at 11:38 AM
Glad you could get it fixed please use 2CarPros.com anytime we are here to help
Best, Ken
Apr 10, 2017 at 11:45 AM
