Code C0034
2012 MERCEDES BENZ C250
50,000 MILES • 1.7L • 4 CYL • 2WD • AUTOMATIC
BILL PARRISH
  • 8 POSTS
Had multiple warning lights come on. EPS, ABS, EPS off, and engine light. pull a C0034 code that indicated that right front speed sensor was bad. replaced that sensor but I cannot clear the code in the vehicle. I can clear diagnostic codes but not pending codes, so the C0034 code is still there and the warning lights all remain lit. additionally the "attention asst" is inoperable. any ideas?
Oct 30, 2017 at 2:13 PM
KHLOW2008
  • 41,814 POSTS
Did you check through all systems and clear all fault codes? Can-bus system is rather unforgiving and if any codes triggered are recorded in other systems, they need to be cleared.
Any possibility the replacement part is faulty?
Oct 30, 2017 at 10:44 PM
BILL PARRISH
  • 8 POSTS
sorry for delay in responding. I actually have TOAD Scan software that I got up and running to see if it could give me more info. see attached. again I cant clear the codes even with the toad software vs scan tool. I have not checked to see if the replacement part is good. I was trying to find info on how to test the part but cannot. can you provide any info on part testing? thank you
Nov 10, 2017 at 6:45 AM
KHLOW2008
  • 41,814 POSTS
For testing of wheel sensors, with a scan tool it should be easy. Go into live data display and monitor the various sensor speed while driving the vehicle around. If you have a hoist, with vehicle lifted or jacked up, manually turning the wheel would allow you to check if it is functioning. However this does not mean the sensor is bad if it is not reading. It just tells you the circuit has a fault and it could be the control unit, wiring or even the sensor pickup ring.
I don't have aceess to our database for the time being so I am not able to tell you the specifications for the sensor for testing. Hopefully I can get this resolved soon
Nov 11, 2017 at 6:40 AM
BILL PARRISH
  • 8 POSTS
i have the TOADscan software and this scan tool (https://www.harborfreight.com/can-obd-ii-scan-tool-with-abs-60794.html) but I cannot see how to or where to check the speed sensors. i took the car for a drive with each scan tool and tried to find how to check speed sensor. i can read systems but i don't see where i would be able to read a component or perhaps i don't know how to use the tools.
I suppose the new sensor could be bad but that would be pretty unusual. any ideas?
Nov 13, 2017 at 12:38 PM
IDK if you can get live data with that tool. Here is a video of a scanner that can get live data.
https://youtu.be/rTtAnsOlZU4
It does sounds like the wiring or ABS module is out. Here is an ABS wiring diagram and a guide to help you see what is going on.
Nov 15, 2017 at 6:33 PM
BILL PARRISH
  • 8 POSTS
thank you for the info and drawings. I watched the video and located the scanner you suggest, however, it appears that this scanner will not work with Mercedes. is that true? is there another one I should consider?
Nov 15, 2017 at 7:14 PM
You might need to get a scanner that works with Mercedes Im not sure if the one in the video supports MB.
Nov 16, 2017 at 10:21 AM
BILL PARRISH
  • 8 POSTS
I recently go a iCarsoft scanner that works with Mercedes. I pulled the following codes from the ESP system C237100, C32600, and C111700 however the fault codes are not in the database of the scanner. do you know or can find out what there are in relationship to?
Nov 24, 2017 at 5:08 PM
I think you can just leave off the 00 at the end of the code number C237100 would be C2371. Have you tried a hard reboot of the computer system? Remove the negative cable from the battery and hold it to the positive cable terminal for 20 minutes this will discharge the capacitors to reset the system protocol.
Please run this test and get back to us.
Nov 24, 2017 at 5:27 PM
BILL PARRISH
  • 8 POSTS
i did do a hard reset and then drove the car at various speeds, WOT, idle and it did not reset. still have the same warning lights and DTC codes.
are you able to determine what those three codes mean or is that something that only a dealer can do?
Nov 24, 2017 at 5:51 PM
It sounds like you have a communication error between one or more of the computers on the network. Did you check all of the fuses because just one fuse out will cause this problem.
Nov 26, 2017 at 12:38 PM
BILL PARRISH
  • 8 POSTS
all the fuses are good. I have been able to find out, possibly, what some of the codes me. c3271 might be the ESP system, c3256 might be the right rear ABS. so with the c0034 right front speed sensor, its all over the car. this seems to suggest that it is a control module of some sort. obviously if I could find that out it would be helpful, otherwise I am going to have to take the car somewhere.
Nov 29, 2017 at 7:52 AM
Did we ever check the wiring between the left front sensor and the control module? Here is a guide to help you just use the wiring diagrams above
Nov 29, 2017 at 11:15 AM
BILL PARRISH
  • 8 POSTS
I will try that now, if I can figure how to get the cover off that thing ;-)
also I access to Mercedes WIS/ARSA if that is helpful. trying to slug my way through it.
Nov 29, 2017 at 1:07 PM
Nov 30, 2017 at 11:35 AM
