Welcome to 2CarPros.
Anything is possible, but when you eliminate the compressor, then the issue becomes not only belt size, but also routing. What I suggest is this: Contact your local parts store. A company called Dorman, which is an aftermarket auto parts manufacturer, produces what is called an AC bypass pulley. Basically, you remove the compressor and bolt on the bypass pulley. They are not expensive. Most are around the cost of a new belt.
If you decide to just replace the belt, I was able to find a belt routing diagram for both with and without AC. It should work from what I can see. With that, you will need a shorter belt. The new belt dimensions should be as follow:
Length - 43.5"
Width - 0.7"
Rib - 5
_____________
I looked up those specs and found an example of what I feel should work. I picked a manufacturer at random. Here is what I found:
Continental Part number 4050435
Let me know if any of this helps or if you have other questions.
Mar 28, 2019 at 7:39 PM
