Bypass AC with serpentine belt
1994 GMC C2500
206,000 MILES • 5.7L • AUTOMATIC
KASSANDRA MCKENNA
I can't find an exact match on a diagram for a bypass AC serpentine belt replacement can you help me
Jul 18, 2025 at 11:46 AM
STEVE W.
  • 15,113 POSTS
There is no easy bypass on those engines. The engines without AC had an idler in place of the compressor. The problem is that there were not a lot of them without AC so the OE brackets are scarce. However there is an aftermarket item that will do what you need Dorman part number 34152 bolts in place of the AC compressor and you run the same belt as it already has. What is the issue with the AC on the truck?
Jul 18, 2025 at 12:12 PM
