Busted head gasket
2000 NISSAN FRONTIER
165,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JIM SCHULTEN
I am going to add a head gasket fix to the radiator as directed on the bottle. It says nothing about how or if I should remove the water from the oil. Assuming I better, what is the recommended procedure to do so?
Sep 22, 2018 at 3:37 PM
Good evening.
First of all, additives for head gaskets rarely work. They complicate things by clogging the radiator and heater core. The proper repair is to replace the head gaskets.
As far as the procedure. You need to drain the block of all coolant. Then add water. Then add your sealer. Let the engine run until it gets to normal operating temperature. Then drain all the water out and fill with coolant.
If you add it to the coolant, it will nothing. The coolant cancels it out.
Yes, the oil/filter needs to be changed to get the coolant out of the oil. If you do not change it, you will damage the main and rod bearings.
Sep 22, 2018 at 3:51 PM
JIM SCHULTEN
Granted some additives may be a waste of money, but so is a $1,500.00 head gasket job on a 2000 pickup with 166,000 miles. Now the question was, how do I get the water out of the crank case and engine itself?
Sep 24, 2018 at 10:40 AM
