I started to smell raw gas burn and black smoke from exhaust pipe. Then one morning it was about thirty degrees out and I had no fast idle. It would idle as if it was already warmed up. The black smoke comes and goes, usually on acceleration and I can go about sixteen miles on half a tank of gas. I have a code reader so I put it on and received like thirteen different codes. I noticed a vacuum line cracked so I replaced it. All the codes seemed to pertain to voltage yet I get 14.6 volts at the battery while running. Also, dip stick smells like gas. It will run and drive okay, but at times when you shut it off and go to start it again, it will shut off. The codes I received are, 117,122,126,327,513,552,553,556,558,565,621,622,624,626,629,631,638,654. I think Haynes had a misprint. It has code 553 twice. The second 553 reads, O Power steering pressure sensor shorted to power. Any ideas or help would be appreciated so very much! Thank you!
Sep 11, 2017 at 8:12 AM
