I hear a low rubbing / clunk type sound in the front driver side tire area whenever I turn the wheel while backing up (ex: backing out of a driveway) only when Im starting it up after letting it sit for some time, i now heard the same sound while driving that wasnt there before but its barely noticeable. Also when turning it off after a normal drive I can smell a burning type smell from the front also, not sure if its more rubber or plastic but its around that type of smell. Just a FYI within the last 6 months i replaced all 4 tires, both front lower control arms, all 4 engine mounts, front struts, rear shocks, front axles, right front outer tie rod and i had 2 recent alignments. Thanks in advance for any helpful reply.
Jul 11, 2013 at 5:25 PM
