Bumper hangs lower on one side
2010 NISSAN TITAN
91,900 MILES • 5.6L • V8 • 4WD • AUTOMATIC
DHATLEY42
Hi My Titan's front bumper seems to be hanging lower on one side than the other. It's never been wrecked and its never been hung up on anything. It's a very well taken care of vehicle. Could this be screws coming loose and how would I quickly fix this?
Dec 5, 2014 at 6:21 AM
HMAC300
  • 48,601 POSTS
the bolts/nuts cold be coming loose if they are use some blue Loctite on the threads and tighten them back up and they shouldn't loosen again unless there is a problem of sometype like a broken weld nut in the frame. Also check for cracked brackets.
Dec 5, 2014 at 7:11 AM
HMAC300
  • 48,601 POSTS
one other thing I forgot is to have a pro check front end components you may have broken a ball joint on the lower side which if that is the case the truck should not be driven and towed to get repaired.
Dec 5, 2014 at 7:37 AM
