Bumper attachment images?
2012 HOLDEN BARINA
80,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
ZMATTJ
  • 5 POSTS
Hi there,
I need to get a re placement front bumper for the Barina and I'm looking for images of the passenger and drivers side mounts/clips that are part of the bumper to make sure that the 2nd hand one isn't missing any.
Thanks for any help and let me know if I need to share more info for you to be able to help me.
Jan 25, 2024 at 6:46 PM
BORIS K
  • 836 POSTS
Your Holden Barina TM is based on the Chevrolet Aveo/Sonic T300.
A good video on how to remove bumper:
https://youtu.be/BSpcAGofna0?si=ZMtR7DU0zcnNjz5D
Below are pictures of a Chevrolet Sonic front bumper.
Accident damaged, right-side mount for wheel arch liner missing.
I could not find any usable pictures for a Holden Barina TM.
Perhaps you could post some clear pictures of your vehicle's front bumper once removed.
Cheers, Boris
Jan 26, 2024 at 7:00 AM
ZMATTJ
  • 5 POSTS
Thanks Boris,
I followed this today and was able to remove and install the replacement bumper I had bought.
Would you also know where I can find info on how to change the gear knob as the current one is falling apart?
Thanks,
Matt
Jan 28, 2024 at 12:13 AM
BORIS K
  • 836 POSTS
Happy to hear that my information helped you to replace the front bumper.
The gear knob simply unscrews.
I could not find a decent tutorial for your model so I will give you the Chevrolet/Holden Cruze video, the setup is very similar as shown in the video. I would advise to apply some Loctite/thread lock to the screw thread before fitting the new shift knob. This will help hold the new item in place.
How to replace shift knob:
https://youtu.be/Pmhd1c53IjA?si=PUQDyuv6pYSdoE4f
Cheers, Boris
Jan 29, 2024 at 2:11 AM
ZMATTJ
  • 5 POSTS
Hi Boris,
I thought it was a twist off, but I’ve applied quite a bit of pressure and it’s not moved. Any suggestions how to confirm if it’s definitely a screw on?
Cheers
Jan 29, 2024 at 3:06 AM
BORIS K
  • 836 POSTS
There are 2 options, either it is screw fit, as previously shown or it is pushed on, secured by a knurled fitting. This should also be secured with a screw under the gear pattern emblem.
Remove the gear emblem, underneath you should then find a screw.
Remove screw and then pull up on the gear knob.
See link:
https://www.csmans.com/transmission_control_lever_boot_replacement-2744.html
I unfortunately have nothing for the Holden brand.
Cheers, Boris
Jan 29, 2024 at 5:58 AM
