2005 Buick Terraza Doesn't cold start
2005 BUICK TERRAZA
OHIO28
  • 16 POSTS
Engine Performance problem
2005 Buick Terraza 6 cyl Front Wheel Drive Automatic 106K miles
The van when starting it up doesn't start without giving it gas. Without giving it gas while trying to start, the engine turns over, starts, then cuts right off.
But when starting and giving the engine gas, the van starts right up, but has a rough RPM idle for a bit. After let'n it run for some time, the van has no problem. This issue has existed for I'd say a little over 6-months.
In looking up the possible parts that might be causing this issue, this van doesn't have a Fuel Pressure Regulator listed.
2-Car Pro's help once again. What are the top possible issues that cause this.
OHIO28......
Oct 19, 2010 at 1:56 AM
KHLOW2008
  • 41,814 POSTS
Hi Ohio28, Here are possible causes for hard starting.
https://www.2carpros.com/forum/automotive_pictures/192750_HardStart01a_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_HardStart01b_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_HardStart01c_1.jpg
Oct 19, 2010 at 8:28 AM
OHIO28
  • 16 POSTS
Again thank you. i will walk down the list to find the possible cause of this issue. Will def let you know what I come up with
OHIO28........
Oct 19, 2010 at 11:37 AM
OHIO28
  • 16 POSTS
Ok, how do you test the current Mass Air Flow sensor? What are the steps and do you also have them in PDF format?
Again thanks much KEN..
OHIO28..........
Oct 19, 2010 at 11:58 AM
KHLOW2008
  • 41,814 POSTS
I will send the file to you. Hope they are helpful.
Oct 19, 2010 at 4:08 PM
OHIO28
  • 16 POSTS
Thank you again and I have downloaded the helpful information and preformed the checks. But what I would like to add was I pulled the MAF Sensor and cleaned it with some Gummount Carb Cleaner as if I were spraying the jet in a carb (Like 1/2 a can). The problem has gone away. The car cold starts, maintains a consistent idle, and even seems to run better.
Thanks again..
OHIO28..... Browns did the Saints bad today....
Oct 24, 2010 at 11:33 PM
KHLOW2008
  • 41,814 POSTS
Glad to know you have fixed the problem.
Yes, a dirty MAF can cause inaccurate signals resultng in starting and running problems.
Thank you for using 2carpros and have a nice day.
Oct 25, 2010 at 7:36 AM
TANGELA YOUNG
I am having the same exact problem... Please tell me what to do to fix it. My van only starts when i give it gas... Then its fine
Mar 21, 2019 at 4:47 PM
JOETECHPRO
  • 705 POSTS
Hey TANGELA YOUNG,
Please start a new question with a description of the fault you are experiencing.
We try and keep each persons questions separate so people can easily follow the thread after it is complete.
Regards, Joe
Mar 25, 2019 at 9:11 AM
