1986 Buick Somerset code 34
1986 BUICK SOMERSET
52,000 MILES • 6 CYL • 2WD • AUTOMATIC
FHLAWSON
  • 6 POSTS
how can you test the sensor when you get a code 34 ?
Sep 20, 2010 at 11:21 AM
WRENCHTECH
  • 20,761 POSTS
That's a Mass Air Flow sensor code. How is the car running?
Did you try clearing the code to see if ti comes back?
Sep 20, 2010 at 11:33 AM
FHLAWSON
  • 6 POSTS
[quote:295cfbadc5="Wrenchtech"]That's a Mass Air Flow sensor code. How is the car running?
Did you try clearing the code to see if ti comes back?[/quote:295cfbadc5]
yes reset code
runs ruff
step on gas---while moving--almost dies like running out of gas
Sep 20, 2010 at 3:46 PM
WRENCHTECH
  • 20,761 POSTS
It's probably a bad sensor but check all the intake snorkels and any attaching hoses or pipes before assuming that.
Sep 20, 2010 at 4:43 PM
FHLAWSON
  • 6 POSTS
[quote:66b6688d01="Wrenchtech"]It's probably a bad sensor but check all the intake snorkels and any attaching hoses or pipes before assuming that.[/quote:66b6688d01]
there are two on the air intake
a small one with two wires and the one with three-i think this is the air mass sensor
Sep 20, 2010 at 5:58 PM
WRENCHTECH
  • 20,761 POSTS
I was referring to making sure there are no air leaks between the sensor and the engine.
Sep 20, 2010 at 6:31 PM
FHLAWSON
  • 6 POSTS
replaced mass air senson senson---same problem
Oct 3, 2010 at 11:33 AM
FHLAWSON
  • 6 POSTS
also get a code 43---dont know what that is
Oct 3, 2010 at 11:34 AM
WRENCHTECH
  • 20,761 POSTS
That means the problem could be elsewhere in the MAF circuit. It can be any of the related wiring or the PCM.
A clogged exhaust will also give a MAF code
Oct 3, 2010 at 11:37 AM
FHLAWSON
  • 6 POSTS
also the oil light is on but the oil pressure is ok
Oct 3, 2010 at 11:38 AM
