need help with 02 sensor 92 skylark 3.3
2002 BUICK SKYLARK
HEYZEUS
i checked the diagnostic trouble codes for my check engine light and was given a 44
lean exhaust/ 02 sensor voltage low.
does anyone know if this means i need to replace the 02 sensor, and if so where is it?
Dec 8, 2006 at 10:47 AM
BACKYARDMECHANIC
  • 337 POSTS
Need more info. How many miles on car? If high mileage I would suspect you need to change the sensor. It should be located in the exhaust system engine pipe before the cat or sometimes located in the exhaust manifold. Good Luck :)
Dec 8, 2006 at 3:58 PM
HEYZEUS
its 288000 miles
but...i found the sensor and replaced it. thanks!
Dec 12, 2006 at 6:14 AM
