1998 Buick Skylark clunking noise
1998 BUICK SKYLARK
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREG DOHERTY
After being stopped, when I let off the brakes, I hear a clunking noise. It does'nt do it all the time. I sense play in the pedal.
Oct 12, 2008 at 1:37 AM
Hi:
There are several things that could cause the noise. Check front end components, ball joints, shock mounts and bushings, and make sure you don't have a loose brake caliper. Also, if it's just a click, it could be a brake pad sticking a little.
I hope this helps. Let me know if you have any other questions after you check.
Nov 14, 2008 at 10:00 PM
