[quote:7761a63063="merlin2021"]This is the TSB for leaks....
Page 1 of 1 WATER LEAKING INTO PASSENGER COMPARTMENT - SEAL VENT -1997 Buic...
TECHNICAL SERVICE BULLETIN
Reference Number(s): 73-10-68 Related Ref Number(s): 73-10-68
ARTICLE BEGINNING
WATER LEAKING INTO PASSENGER COMPARTMENT (APPLY RTV SILICONE SEALER TO TOP VENT GRILLE ASSEMBLY)
Model(s): 1996-98 Buick Skylark
1996-98 Oldsmobile Achieva
1996-98 Pontiac Grand Am Section: 10 - Body Bulletin No.: 73-10-68 Date: April, 1998
CONDITION
Some owners may comment on water leaking into the passenger front floor area.
CAUSE
Condition may be due to poor adhesion of the top vent grille assembly to the windshield. The existing seal tape can separate from the glass or the grill above the A/C air intake canister and allow water to overflow into the passenger front floor area.
CORRECTION
Remove the top vent grille assembly. Clean the grille assembly and the surface of contact on the windshield of all sealing tape and adhesive residue. Apply a bead of RTV Clear Silicone Sealer from 3M(R), Part #08662, or equivalent, to the underside of the top vent grille assembly where the old seal tape was removed. Reinstall the grille. Wipe excess RTV Sealer horizontally across sealing area to achieve a smooth finish.
WARRANTY INFORMATION
For vehicles repaired under warranty, use:
WARRANTY INFORMATION Labor Op Description Labor Time D1353 Panel, Cowl Vent Grille - Reseal (complete) 0.8 hr
© 2007 Mitchell Repair Information Co., LLC.
http://www.ondemand5.com/mric/common/asp/printart.aspx
10/18/2008[/quote:7761a63063]
the problem is drivers side not passanger side
it would be great to get fixed that easy if its a problem like that
Oct 18, 2008 at 4:12 PM
