1997 Buick Skylark dome light stays on
1997 BUICK SKYLARK
15,000 MILES • 4 CYL • 2WD • AUTOMATIC
NOTHINGSEVEREASY
Can you tell me why my dome light stays on continually?
I've had to remove the bulb & bought a new fuse, thinking it might be a fluke or something... but finally had to take out the bulb.
But now I dont have a light in the car.
Thanks!
Sep 26, 2010 at 7:23 AM
HMAC300
  • 48,601 POSTS
first make sure your switch isn't on for your dash lights as that turns the dome on. then check your fuses. this could also be a door swith or the courtesy light module tha tis in the convience center near the steering wheel under the dash. It could also be a broken wire from one of the door switches. If you are goign to check that try the drivers door first.
Oct 2, 2010 at 9:12 AM
