1996 Buick Skylark W/S washer
1996 BUICK SKYLARK
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
RJOWENS
The W/S washer does not work even with a full reservior. Looking for where the fuse is and wow to access the pump. The reservior seems to be under the battery, behind the drivers side front fender.
Thanks so much.
Jan 1, 2010 at 9:15 AM
It is a pain. You need to remove the innder fender cover to access it. Do that and using a test light, check to see if the pump is getting power.
Let me know what you find.
Jan 12, 2010 at 8:50 PM
