1995 Buick Skylark TEMP
1995 BUICK SKYLARK
200,030 MILES • 4 CYL • FWD • AUTOMATIC
RIMRUNNER
Hadaraidator leak and fixed it . It is not leaking know .But wile drive the temp gage needle move,s between 110 and 120 is this normal or do I have a stuck thermosstat . thank you
Feb 19, 2008 at 4:27 PM
BLACKOP555
  • 10,386 POSTS
sounds like you have a low coolant level, a little bit of variation is normal as the coolant fan is probably coming on and off.
if the thermostat was stuck you would be overheating and definetely higher then 120
Feb 19, 2008 at 8:19 PM
