1995 Buick Skylark Please help.
1995 BUICK SKYLARK
AKICIELINSKI
Electrical problem
1995 Buick Skylark 4 cyl Automatic 90k miles
My car runs fine in reverse. It also idles fine in P and N there are no lights on indicaring any problems. When i put the car into D 1 or 2 it stalls, sometimes i can get it to go an inch or two but then it stalls. I replaced the computer and the o2 cencor and now i am out of ideas. Please help, this is my only car.
Nov 11, 2008 at 5:23 PM
MUSTANG87
  • 261 POSTS
sounds like your car needs a new lock up solenoid in the transmission.not to hart to change its on the side of the transmission u gotta remove the pan that goes on the top side of trans not the bottom oil pan but the one on the side that looks like a pan.or just disconnect the plug on top of the trans that goes to the lock up and your car will run again but will lose a little power and burn little more gas but very drivable.best thing is to just fix the problem not to expensive.part will run from 35 bucks and up.good luck
Nov 11, 2008 at 8:03 PM
