1993 Buick Skylark How much to replace struts
1993 BUICK SKYLARK
14,000 MILES • 6 CYL • FWD • AUTOMATIC
HARRIET49
I need an approximate value of how much it will cost to replace a strut . And do you have to replace both at the same time.
Jul 25, 2009 at 11:38 AM
I recommend having the both replaced at the same time. Also, I would est. around 200.00 to replace them. Based on where you live can change that. Also, make sure to have the front end realigned after the work is done. When the struts are removed, the alignment is affected.
Sep 29, 2009 at 12:59 PM
