1993 Buick Skylark Fuel System
1993 BUICK SKYLARK
ENGTECH200
Engine Mechanical problem
1993 Buick Skylark 6 cyl Two Wheel Drive Automatic
Car starts and runs off of starting fluid only. I have checked the fuel pump (Working), replaced old fuel filter. I am thinking maybe the FPR may be bad but I am not sure how to test it. Can you help.
Note: Car ran fine until low speed stop (under 5 mph) at stop sign, car surged then died. Car will crank but no start. Also I have checked the fuse(s).. all are good.
interior of car got soaked overnight from rain storm, daughter left windows down...
Jul 6, 2010 at 10:57 PM
Check the fuel pressure with a fuel pressure tester if its within specs and also if the injectors are pulsing
Jul 7, 2010 at 6:36 AM
