1992 Buick Skylark leak
1992 BUICK SKYLARK
JRSEYDI
Transmission problem
1992 Buick Skylark Engine Size unknown Front Wheel Drive Automatic 70,000 miles
It appears as if the transmission fluid is leaking from my car as I see red fluid in the driveway. I fill the fluid and the car runs fine for a coupld weeks then I need to fill again. I was told by a mechanic that my seal need to be replaced but it is on the side and requires a special tool to reach it. Is this correct and is it a fairly easy repair?
Jan 11, 2008 at 11:21 AM
BLACKOP555
  • 10,386 POSTS
Yes they are telling you the truth, i would take it in to a reputable mechanic, you should not attempt to do this yourself.
Jan 11, 2008 at 12:11 PM
